Originally Posted by Traben13
I have the grip on the bar and the housing is clamshelled as far open as i can get it, I can attach the top cable but then i dont have enough slack to wrap the bottom one around the grip.
I had the same problem, put the cables on the grip off of the bar first, then slip the grip over the bar, but you need to remove the little deal that holds the cable to the frame in order to have enough slack to slip the grip over the bar. Give it a try.
