Originally Posted by Canadian fury
Looks good. How did the wiring go? Pretty straight forward? Hopefully mine shows up this week.
I had to re-work the bracket / hard bag bracket I have uses the front hole on the bike frame / the wiring connections are quite easy / also as suggested on a post I'm going to bring the wiring back under seat area so that I will only have the led cables running under fender/ I found the best fit for the led (help from JW/MFR) the bracket has to move back 3/16" / guess my frame is different than the 1 Raw Design modeled the bracket for !!!!
Today will be final fit and wiring , I still need to drill the new front hole on frame and bracket , paint and finish,
When yours arrives I can walk u thro the connections if u need.
