Climate Control - Honda Fury Forums: Honda Chopper Forum
Old 01-13-2012, 07:10 PM   #1 (permalink)
Default Climate Control
To say it works is an understatement !
Thought about an ON/OFF switch but since the vest is so responsive
it would require frequent switching and possibly difficult to operate while riding and wearing gloves.
A remote digital temperature controller was the better choice even if it cost as much as the vest
or twice as much as a standard bulky and fumbley 'inline' controller.
Gerbing's remote switched digital controller for permanent installation makes adjustment easy.
The LED displays short blink/long pause for rare, long blink/short pause for medium and steady ON for well done .
The digital controller is under the side cover next to the battery and is hard wired into a switched accessory port relay.
The remote control knob pot and LED just fit in the small space under the ignition switch cover not occupied by the 'radiator' cap
after very careful measuring (see attachments).
Climate Control-img_0019-copy.jpg   Climate Control-img_0020.jpg   Climate Control-img_0023.jpg
Old 01-13-2012, 07:18 PM   #2 (permalink)
Jag30's Avatar
Slick system!
Jag30 is online now   Reply With Quote
Old 01-13-2012, 07:21 PM   #3 (permalink)
EvoMotors's Avatar
Do they make one with cooling?
EvoMotors is offline   Reply With Quote
Old 01-13-2012, 07:27 PM   #4 (permalink)
Yup, it's called north of the 49th parallel.
Old 01-13-2012, 07:40 PM   #5 (permalink)
khhammer's Avatar
Hey, that's pretty cool! Or in this case Pretty Hot!!
khhammer is online now   Reply With Quote
Old 01-13-2012, 08:34 PM   #6 (permalink)
thenewaftermath's Avatar
Ha... I knew you would come up with something new. Lol.....I sure could use that setup right now. It was 57 yesterday and 30 degrees today.
thenewaftermath is online now   Reply With Quote
Old 01-13-2012, 10:20 PM   #7 (permalink)
Dave Maher's Avatar
Send a message via AIM to Dave Maher
Gar, you are the true gadget man. Very nice!
Life is good!
Dave Maher is offline   Reply With Quote
Old 01-14-2012, 02:01 AM   #8 (permalink)
grapnel's Avatar
could have used that on the ride today, was 28 degrees by the time i got home.
grapnel is online now   Reply With Quote
Old 01-14-2012, 10:20 AM   #9 (permalink)
DavidS's Avatar
I wish I had thought to mount mine there. Very cool. I chose a different place.
D
DavidS is online now   Reply With Quote
Old 01-14-2012, 04:45 PM   #10 (permalink)
You can get an evaporative cooling vest from whitehorsegear.com
I have one and it works well if you have a jacket with lots of air flow.
