Originally Posted by 2 Evil
It was a pain in the cock to do my last oil change with that damn thing ...
Sounds like you were using the wrong tool, LOL.
Or, you could use slip joint pliers (for removal only) ...
Just move the rubber hose temporarily out of the way
Since I don't need the space ... yet, I'll leave my charcoal canister where it is for now.
If you do remove it, remove the solenoid too then plug the vacuum line and tuck it away for later so you can connect to a hypercharger to make the flaps work
