Lowering rear end....help - Page 4 - Honda Fury Forums: Honda Chopper Forum
Old 09-19-2012, 09:59 AM   #31 (permalink)
J BUCK's Avatar
Originally Posted by jw View Post
His system is cool, it pumps down so if he should ever have pressure loss Therapy goes up not down !! The platinum if it loses pressure bike goes down and your done.
"your done" what does that mean? You can still ride the platinum at its lowest height or no air pressure.
J BUCK is offline   Reply With Quote
Old 09-19-2012, 12:33 PM   #32 (permalink)
Going by what MFR was telling me that if the air ride loses pressure it would not be able to ride back although never heard of it happening Murphy's law would visit me!!
Sent from my iPhone using Motorcycle
Old 09-19-2012, 01:04 PM   #33 (permalink)
J BUCK's Avatar
With no air in the cylinder at all the bike is still ride able. I mean you can't ride as if it was at stock height, but it’s a safety feature of the system.
Old 09-19-2012, 02:23 PM   #34 (permalink)
That would solve my Murphy's Law concerns.
Old 09-19-2012, 04:43 PM   #35 (permalink)
habadir's Avatar
Originally Posted by habadir View Post
This is a question for the ones that modified the stock spring :
What' did u use to support the spring or to hold it to grind it ?
What did u use to grind it ?
Does it have to be perfectly level ?
Anyone can help ?
habadir is offline   Reply With Quote
Old 09-19-2012, 05:46 PM   #36 (permalink)
Send a pm to MyFuryRider .
Old 09-20-2012, 02:07 PM   #37 (permalink)
Tim5779's Avatar
Send a message via Yahoo to Tim5779
habadir, a belt sander with a table is the quickest way. set the table at 90° to get it square in the up and down direction, then clamp a 90° angle block (or angle iron will work) to the table to keep it square in the left and right direction...and grind away. keep a bucket of water close by so you can dunk the spring every 10 seconds or so.....good luck.
Sent from my SPH-D710 using Motorcycle.com Free App
Tim5779 is offline   Reply With Quote
Old 09-20-2012, 02:08 PM   #38 (permalink)
Tim5779's Avatar
but as JW said...MFR probably has a setup that will do this in no time
Old 11-21-2012, 02:04 PM   #39 (permalink)
fknhrdcr's Avatar
Is the following video basically what needs to be done to the spring for the lowering mod? 1/8 inch off each side and keep it cool right?
fknhrdcr is online now   Reply With Quote
