Head Light Switch - Honda Fury Forums: Honda Chopper Forum
Old 12-04-2012, 06:24 PM   #1 (permalink)
Default Head Light Switch
Headlight switches off with engine kill switch while key is still ‘ON’ reducing battery drain and allowing max current to switched accessory (air pump for example). Green wire from relay goes to headlight ground; all wiring, connections and relay added inside headlamp housing.
Seņor Gar is offline   Reply With Quote
Old 12-04-2012, 08:30 PM   #2 (permalink)
Very handy especially if you had to pump your tyres up after you had a flat.
Old 12-04-2012, 11:04 PM   #3 (permalink)
EvoMotors's Avatar
I think it's a very good idea
EvoMotors is offline   Reply With Quote
Old 12-05-2012, 12:15 AM   #4 (permalink)
Old 12-05-2012, 12:50 AM   #5 (permalink)
Furious Brit's Avatar
Seņor Gar Strikes again.******* Superb!***** thanks mate
Winston Churchill
Old 12-05-2012, 04:05 AM   #6 (permalink)
2Dirty's Avatar
Can you be more specific? I have a Sabre and last night I had the entire wiring pulled in the headlight to put in a HID kit. I did not see a relay like in your picture. Is that in the headlight? Are your adding a green wire or moving the connections? Maybe a before - after would help.
Thanks!
2Dirty is offline   Reply With Quote
Old 12-05-2012, 09:21 AM   #7 (permalink)
EvoMotors's Avatar
Thanks!
This is the additional relay Gar installed to achieve the functionality.
Old 12-05-2012, 03:28 PM   #8 (permalink)
Factory wiring ...
Switched wiring ...
All wiring, connections and relay added inside headlamp housing.
Old 12-05-2012, 05:09 PM   #9 (permalink)
2Dirty's Avatar
Thank you
