Easy Seat R&R - Honda Fury Forums: Honda Chopper Forum
post #1 of 19 (permalink) Old 12-05-2012, 04:07 AM Thread Starter
Septuagenarian Rider
Location: West End of the 49th Parallel on a US 2010-ABS/LB-Fury
Easy Seat R&R
Originally Posted by CDESTROYER View Post
If you must remove the seat for any reason I highly recommend getting a friend to pull the seat cushion over for you so you can tighten, untighten the hex nut. Its just difficult to pull the seat cushion over, align the holes, screw in the hex nut without stripping the bolt.
I had to order two more bolts, hopefully they will screw in straight.
<pics<>links> *V-Mod * Factory X Forwards * Bagger Convertible
With a C&C seat, Xtended Forwards and Cannella Risers, 500 mile days are a breeze .
Seņor Gar is online now
post #2 of 19 (permalink) Old 12-05-2012, 10:24 AM
EvoMotors's Avatar
Garage
Recycling the empty oil cans?
EvoMotors is offline
post #3 of 19 (permalink) Old 12-05-2012, 10:57 AM
Great idea Senor Gar. Should have thought of that.
Wildman is offline
post #4 of 19 (permalink) Old 12-05-2012, 04:16 PM Thread Starter
I had to order two more bolts, ...
I did too since I've had the seat off & on probably a hundred times . The hex socket holes do wear out . Problem is Honda supplied a different bolt with a shallow socket half the depth of the original not to mention the small head . What did you get CD .
post #5 of 19 (permalink) Old 12-05-2012, 04:28 PM
The one you wallowed out on the right.
Had to retap the housing to.
When I finally got the allen bolt in I overtightened it and caused the f*&#%! fender to crack.
Honda replaced the fender under warranty.
Wildman is offline
post #6 of 19 (permalink) Old 12-05-2012, 04:42 PM Thread Starter
Any chance yours has a different part number than the replacement I got on the left .
post #7 of 19 (permalink) Old 12-05-2012, 05:01 PM
I didn't save the bag Senor but I know it was a grey color and shaped exactly like the one on the right.
Wildman is offline
post #8 of 19 (permalink) Old 12-05-2012, 05:12 PM Thread Starter
I didn't save the bag ...
I got 4 of those useless bolts and they appear to be the correct part # so I have substituted a proper socket bolt with enough depth that it won't self destruct and risk seat damage to grind it out. The C&C solo seat is almost an 1" wider over the bolt and there was no way in hell that I could get it on or off by myself until I cut out that plastic seat shield .
post #9 of 19 (permalink) Old 12-05-2012, 05:36 PM
OBSIDIAN's Avatar
I just stand on the opposite side of the bike. You can pull the seat back with one hand and screw with the other. I think I'm just going to remove the seat bracket all together and install it with industrial velcro so it sits lower and tighter on the fender.
OBSIDIAN is offline
post #10 of 19 (permalink) Old 12-05-2012, 05:44 PM
About a week later I ordered the Mustang seat and then the 2 seat bolts were open to view. Doesn't look great but sure beats the anguish of stripping bolts and housings.
Amof my Mustang fender bib is being delivered today to fill some of that space on the rear fender from switching to the solo seat.
Wildman is offline
Human Verification
