Sissy Bar Mod
OK, there has been a lot of talk about the lack of options for sissy bars for the Fury.
I have read all of the threads and there are some good vender products and some really good member ideas out there.
So to add to the options (or confusion) here is mine.
The first mod I did was Corbin fairing and hard bags. When the stuff arrived, the mount system Corbin came up with seemed very simple and very effective.
And I thought that it could resolve the sissy bar issue. The following is a step by step of the process.
I have all of the manufacturing and installation details in a pdf available to ANY member that asks for it.
Material List:
ITEM QTY DIMENSION NOMENCLATURE
1 1 1/8 x 12 x 12 T-316 Stainless Steel Sheet or Mild Steel
2 1 1/4 x 6 x 6 Blanchard Ground Steel Plate
3 1 0.5 x 0.5 x 6.0 Square Stock Steel
4 4 12mm x 1.75 x 30 Stainless Allen Flat Head Screw
5 4 12mm x 1.75 x 20 Chrome or Stainless Button Head Screw
6 1 N/A Blue Loctite Thread Locker
Here are the raw materials I used.
Step 1 Cut 2 pieces of 1/4 inch thick plate steel per drawing, these are the mount plates.
Step 2 Drill to 2 holes per drawing to clear a 12mm flat head screw and counter sink.
Step 3 Drill 2 holes per drawing and tap 12mm x 1.75.
Step 4 Prime and paint or powder coat both pieces.
Step 5 Cut 2 pieces of ˝ inch square stock 3 inches long per drawing, these are the spacers.
Step 6 Drill 2 holes in each to clear 12mm screws.
Step 7 Cut 2 pieces of 1/8 inch thick T-316 stainless sheet metal (you can use mild steel but it will have to be chrome plated or powder coated) per drawing, these are the side plates.
NOTE: This is going to be chromed or polished so cover both sides with masking tape to protect the surfaces. This will make it easier for the chrome platter or polisher if there are no scratches in the surface.
Step 8 Drill 2 holes per drawing to clear a 12mm button head screw.
Step 9 Round the edges inboard and outboard so the wife/girlfriend wont cut her A$$ and chew yours out.
Step 8 Remove the 5 screws holding on the rider and passenger seats and remove the rear fender, this is done with the 5mm allen wrench under the ignition switch cover.
Step 9 To keep the tail light sub-frame assembly aligned do one side at a time. Remove the 2 12mm bolts that hold the tail light sub frame to the rear of the frame (KEEP these incase you want to go back to stock).
Attach the 1/4 plate to the outside of the frame with the counter sunk holes at top facing out and fasten in place with the 12mm flat head bolts (through the 1/4 plate then the frame and into the sub frame) and torque to 6 ft/lbs. repeat for other side.
Step 10 Replace the rear fender and reinstall the rear passenger seat screw to hold the fender in place.
Step 11 Install the side plate onto the mount plate with 2 12mm button head screws and ˝ inch spacer. Hand tight only. You are looking for a 1/8 inch clearance between the side plate and the fender.
Step 12 Mark the side plate at the point where the fender starts to curve in. remove the side plate.
NOTE: Mark the side plate at 90° to edge of side plate, this will allow the side plate to bend at the same angle as the fender. See image below.
Continued in next post.
