Is there a tool to loosen and tighten the upper lock nut for the clutch cable?? Because the gorilla at my dealer musta used his teeth to tighten it. Now I can't loosen it to re-adjust my clutch.
NM. Just use a cloth over the nut and channel locks to crack it loose. Then use fingers rest of the way.
