additional power outlet??? - Page 3 - Honda Fury Forums: Honda Chopper Forum
Old 06-15-2011, 10:02 PM   #21 (permalink)
QbanFury's Avatar
FIXER bikes do have alternators, but your point is well taken because you definitely don't want to leave any gadget hanging on the bike!!!
QbanFury is online now   Reply With Quote
Old 06-15-2011, 10:06 PM   #22 (permalink)
Originally Posted by woodenhorse View Post
I thought about a battery connection that has 30 amp inline fuse....I don't think I'd want to settle for less than 15 amp.
That would not be a good idea, the main fuse for the whole bike is 30 amps, most add on power plugs are only 5 -7 amps.
Old 06-15-2011, 10:56 PM   #23 (permalink)
Now that I'm getting this new battery, I want to install a dual cigarrete power outlet on my bike. I've check around and saw that I can get a weatherproof one with only one outlet. Anyone know if there is a dual outlet available that wires directly to battery with inline fuse? I've seen the adapters you can get to plug into an existing outlet that have two outlets, but I don't want that.
Anyone have outlets mounted on their furys?
This works. Then you can use a bosch/BMW plug to any cigarette plug (dual or single). Switch lets you turn it on or off for things like electric vest or charging adapters for phones cameras etc.
Cheers!
Spud
Spud is offline   Reply With Quote
Old 06-16-2011, 07:51 AM   #24 (permalink)
StPeteAPB's Avatar
BurnsMoto, Yo! The same guy who made that USB socket I put on the bike in this thread:
BurnsMoto USB Port Install - How To
Here's the dual:
Here's the powerlet socket:
(both pics are linked to BurnsMoto's products shown)
Old 06-16-2011, 09:25 AM   #25 (permalink)
woodenhorse's Avatar
Originally Posted by peteru View Post
Dang......lots of stuff, nice toy!
Old 06-16-2011, 09:29 AM   #26 (permalink)
Thanks Clueless, I'll keep it toned down....just want to run radar detector and gps (could be either/or) and maybe hand held cb or scanner with ear plug or something......
Old 06-16-2011, 09:31 AM   #27 (permalink)
Interesting set up! Thanks for the ideas!!
Old 06-16-2011, 09:47 AM   #28 (permalink)
Here's the dual:
Thanks St. Pete, I'll check into it. Ya'll have given me lots of good info and ideas....I'll mull over it for a while then go for a solution. Thanks Guys!
Old 06-16-2011, 12:32 PM   #29 (permalink)
BarFury's Avatar
Originally Posted by FIXER View Post
.............i could be wrong but i don't think bikes have alternators like cars that charge the battery while driving...........
FWIW, ALL Honda's have come equipped with A/C Alternators, ever since they first graced these shores in the late 50's. I don't remember ANY Honda ever coming equipped with a D/C Generator. Older Harley's and some British bikes had Generators, but even they, finally, upgraded.
BarFury is offline   Reply With Quote
Old 06-16-2011, 02:41 PM   #30 (permalink)
captainfester's Avatar
Thanks, nice setup!! Any problems drilling out the plastic side cover?
i drilled the side cover to mount my air ride switches. just like easy e did. very simple. just used a very small bit and then moved up size by size till i got where i needed. although i bet if u had a pilot hole with a small bit you could go bigger right away.
i just didnt want to over shoot the switches.
captainfester is online now   Reply With Quote
