Was out riding and noticed the right side is leaking and I assume it must be when it hit ruts or bumps but does leak ! Has anyone else had this issue ? O-ring looks ok and it is tight so not sure of cause . Guess I'll try using one of the OEM rings .
Others have had trouble with this. When I installed I put some RTV Silcone on the o ring and even a little on the threads before I put it together. No leaks. I also used a strap wrench to tighten the extensions.
what jag said.i always use rtv silicone on extention threads.
