Bigger than 240 on kosman rim - Honda Fury Forums: Honda Chopper Forum
Old 11-17-2012, 09:35 PM   #1 (permalink)
Odiefords's Avatar
Default Bigger than 240 on kosman rim
I was kinda wondering if anyone has mounted anything bigger than a 240 on a kosman modified rim. I have found people who are running a 240 on a stock wheel but can't find any info if someone has tried a bigger one yet. Anyone...... Anyone.........
Odiefords is online now   Reply With Quote
Old 11-17-2012, 11:23 PM   #2 (permalink)
Night Fury's Avatar
Have you seen the L&M video on YouTube about the Kosman mod? There's very little room between the frame and tire. I seriously doubt you can go any larger without further modification.
Old 11-17-2012, 11:29 PM   #3 (permalink)
Odiefords's Avatar
But it's tight between the seat frame . The swing arm has room for maybe a 250. Was just wondering since the seat frame can be spread with a bottle jack
Old 11-18-2012, 01:37 AM   #4 (permalink)
Night Fury's Avatar
Look into the Sumo T-mod also.
Old 11-18-2012, 02:59 AM   #5 (permalink)
Odiefords's Avatar
I have. I can't drop 5k just yet. Was gonna do the kosman mod but was just thinking out loud
Old 11-18-2012, 03:36 AM   #6 (permalink)
Furious Brit's Avatar
I wouldn't want to try that without some serious heat, plus it would be easy get the seat frame out of line or twisted.
Winston Churchill
Old 11-18-2012, 04:09 AM   #7 (permalink)
Odiefords's Avatar
Not sure if it would matter. Its a seat frame. So long ad it cleared. Anyway I was just wondering if anyone had tried it
Old 11-18-2012, 08:39 AM   #8 (permalink)
Night Fury's Avatar
No. No. No! There's another mod I recently read a thread on called the Sumo T-mod. Basically you're going to outline your rear frame onto cardboard for a pattern. The cut that into 1/4" plating. Weld that at that base of the frame where the seat is like when installing the Sumo struts. The cut, widen, and reweld each cross brace one at a time. Finally remove the stock frame. It doesn't give much extra clearance. But it will work.
Old 11-18-2012, 08:42 AM   #9 (permalink)
sinister1's Avatar
U still need a wider swing arm
Sinister1
sinster1-2010 matte silver,accutronix side mount plate holder,zombie levers,MFR MONGOS,custom mirrors,DLX spike t-band chrome grips,accutronix air cleaner adapter,demons cycle spike chrome air cleaner,L&M lowering spring
sinister1 is offline   Reply With Quote
Old 11-18-2012, 08:45 AM   #10 (permalink)
Night Fury's Avatar
Sinister1
That's what I was saying! 240mm is the widest one can go without further modifying the bike.
