02-06-2012, 09:49 AM
#31 (permalink)
Originally Posted by thrifty
Some of ya'll should have just bought a HD if you're just gonna try and imitate one....
Hahahaha that is what I was thinking but didn't say. There is truth there I think.
02-06-2012, 10:32 AM
#32 (permalink)
Originally Posted by Seņor Gar
Maybe  .
You'd have to ride it once in a while instead of sitting around idling trying to impress all your Harley buddies  .
They're already impressed. My concern is the "sitting around" may be that of a mechanical failure if this mod burns something up. Then, you definitely have an HD-like bike!
02-06-2012, 08:11 PM
#33 (permalink)
I like the way it Idles. sounds like a big block...and I dont want no dam harley
Regards,
dewking:dam plastic head covers
 DAM Plastic Head Covers
04-03-2012, 05:14 AM
#34 (permalink)
an another idea perhaps would be to disconnect IAC and input a fixe value voltage on it !....
With some electronic, one could have something like this :
with water temp sensor voltage values, when engine cold, electronic could let ECU drive IAC, and when engine hot, electronic automatically switch ECU IAC circuit and input a fix voltage in IAC who could be adjust with one potentiometer for adjusting idle...
Perhaps needing a resistor somewhere in this electronic circuit (like an O2 sensor eliminator) to not having engine light on..
no need to drill anything, no need switch...
For someone who know electronic, I think it was very easy to do
Brigitt Bardot doesn't recognize anybody any more in Harley Davidson... Sexy girls lose their strings in Fury
04-03-2012, 08:30 AM
#35 (permalink)
Is there any concern about insufficient oil pressure if the idle is set too low? I seem to recall (from my VTX) that if you dropped the idle too low, you may run the risk of damaging the engine from poor oil circulation. Possibility?
04-03-2012, 09:24 AM
#36 (permalink)
Yes I think in absolute it's possible... But I think idle would be very very lower for that, and :
1 - modern pump and oil have high performance today
2 - I reminber some carb hd who had very lower "pot....tato....... pot pot..... potato" idle  without fatal issues !
3 - one never let ours engines in idle for long time
4 - must to be confirmed (depending oil pressure sensor location), but if pressure is very lower, light oil would must light on in theorie !
I reminber in sixteen, in france there was THE DS Citroen car... the top of technology at this time...there was a fucking big red light about 5 cm ø in middle on dashboard. When it light on, manual said you must stoped engine immediately...
Mechanic said citroen would have had wrote on it "too late"... because in fact, when it ignited, engine was already dead !
04-03-2012, 09:27 AM
#37 (permalink)
That would be my thought. The purpose of the low oil pressure light is just that - to alert you that oil pressure is at a level where the engine is at risk. If you lower the idle and the light doesn't come on, you should be safe.
04-03-2012, 10:26 AM
#38 (permalink)
IACV is a 4 wire stepper motor driving an idle air screw valve
04-03-2012, 10:49 AM
#39 (permalink)
Ah shit !  too bad ! it was a good idea
