Need help with powercommander switch - Honda Fury Forums: Honda Chopper Forum
Old 01-07-2012, 06:36 PM   #1 (permalink)
French-Guy's Avatar
Default Need help with powercommander switch
Hi guys,
My PCV Is installed. Every thing is ok. But there is some thing that I find strange.
I Have install a switch for two maps... and send to PCV the two maps...
the config is ok... switch enabled, etc...
No problems with all that...
But, when I launch the software on my laptop and connect the pcv, if I toggle the switch for the second map the dysplay on the right always show " current map : 1" anyway
I think it's strange !... When toggle the switch, dysplay must switch betwenn 'current map : 1" and "current map : 2" ? Yes or no ?
is someone can tell me if it's normal or not ???...
thank's for your answers....
French-Guy is offline   Reply With Quote
Old 01-07-2012, 07:45 PM   #2 (permalink)
dewking's Avatar
Originally Posted by French-Guy View Post
Hi guys,
you just have to send the map so your pc is connecting to the loaded map, just a thought.
Regards,
dewking
DAM Plastic Head Covers
dewking is online now   Reply With Quote
Old 01-08-2012, 04:33 AM   #3 (permalink)
French-Guy's Avatar
Yes,
Am I ok with that. But when you load two maps and flip the switch the pc would show current map selected by the switch, I think !..
When you start engine, on the right of the pc there is the rpm, current map selected, and other... So when you flip the switch I don't understand why current map don' t change...
The problem is that I m not sure flipping switch change really the map.. It s not function :-(
This screen "current map" appaers only when you load two maps, so...
I will load two map with very different values at iddle to see if I heard a difference
Problem is if the two switch ports on the pcv don't work perhaps when I will install my autotune module it doesn't work :-( because it's this same switch who connect autotune function.... :-(
Old 01-09-2012, 03:39 PM   #4 (permalink)
The bike has to be running, when you change the switch, you should see the current map change from 1 to 2, or vice-versa.
Dynojet Research
Technical Support Team
DynojetResearch is offline   Reply With Quote
