Originally Posted by French-Guy
Hi guys,
I had install my pcv and autotune.
Powercommander recommand to block pair valve for correct values.
So, I have read all threads about pair valves here...
Juste a question :
Can't we just disconnect the electric wire on the valve ?
can't we just put a plug in the air filter hole to stop the air in this circuit ?
if you just block them off do as close to the pair valve assembly as possible, I took a bolt and cut the lines close to the pair valve then used some sealer on the bolt and put it into the tube I cut off. I thing I used a 7/16 thread and threaded it into the tube a 1/2 inch away from the pair valve assembly.
Regards,
Dewking
 DAM Plastic Head Covers
