pair valves/autotune : a very good idea never read here and a question - Honda Fury Forums: Honda Chopper Forum
Old 01-31-2012, 06:41 AM   #1 (permalink)
French-Guy's Avatar
Default pair valves/autotune : a very good idea never read here and a question
Hi guy
- So, in first, pair valve must be removal for use with autotune.
- With a switch on the PCV we could choise between autotune mode or base map.
So, with a tri-polaire switch it would be very easy to have :
- position 1 : base map + pair valve controlled by ECU
- position 2 : autotune and pair valve closed (by input direct 12 V on solenoid valve to closed it)
I think It's not a so stupid idea because (in france) there is sometime some controls on streets to see if your engine is "clean" and don't pollute...
So flipping a switch, could be a good idea !
The only question : To be closed, the solenoid valve must be on with 12 V.
I have tried, and have seen the solenoid became hot after 5/10 min,
My question :
If I have understand pair valve function if we stay in full trhottle on an away for exemple, pair valves are closed... But it's never for a very long time...
So, is someone know if a solenoid valve can support to be always on 12 v for very long time whitout burn and destroy ?
French-Guy is offline   Reply With Quote
Old 01-31-2012, 11:43 AM   #2 (permalink)
dewking's Avatar
Originally Posted by French-Guy View Post
Hi guy
My question :
Its defiantly going to heat up with 12 volts applied to it for extended time, you would be better off to disable it, the pair system only lets oxygen into the exhaust to help ignite unburned gas in the exhaust pipe and if you do a after market exhaust then you wouldn't pass your "clean inspection" anyway unless the after market exhaust has a catalytic converter in it.
Regards,
Dewking: dam plastic head covers
DAM Plastic Head Covers
dewking is online now   Reply With Quote
Old 01-31-2012, 12:03 PM   #3 (permalink)
If it is just a visual inspection insert a ball bearing to seal the intake PAIR hose just behind the air cleaner .
Old 01-31-2012, 12:48 PM   #4 (permalink)
French-Guy's Avatar
Regards,
Thank's for opinion...
With after market exhaust without catalytic converter, it's sure... Mine have one converter
I told me too, when I ride in town, in the traffic, it's a good idea for clean inspection AND for our planet !
But I think this solenoid valve is not made to be under 12 v every time and will probabely burn quickly
Old 01-31-2012, 06:24 PM   #5 (permalink)
thenewaftermath's Avatar
and i thought our emissions were tuff. Im glad Im not moving to Paris any time soon. LOL
thenewaftermath is offline   Reply With Quote
Old 03-13-2012, 12:24 AM   #6 (permalink)
DmanOz's Avatar
Default Popping
Thats more or less exactly what my tech did, and now zero popping.
DmanOz is offline   Reply With Quote
Old 03-13-2012, 08:44 AM   #7 (permalink)
Europe does yearly inspections on their vehicles and you have to take them in to get inspected, they check brakes, position of lights, for any leaks, exhaust leaks, defects in the body of the vehicle, and if I remember right they hook up a machine to the exhaust to check emissions, I left Germany in 04 and I have a crappy memory lol.
Old 03-13-2012, 05:35 PM   #8 (permalink)
French-Guy's Avatar
Yes for cars, it s call "contrôle technique" , but this law is not yet available for bikes...
And it s why i don t want to do not reversible things on my fury !
This switch for pair valve was ā good idea but i test the valve with continu 12v, and it s become very hot after few minutes, so i think, this solenoid valve is not made to be on 12 v permanently :-(
Brigitt Bardot doesn't recognize anybody any more in Harley Davidson... Sexy girls lose their strings in Fury
