LED's W/ Load Equalizer Issues
So I installed LED rear turn signals with a load equalizer and am having an issue. When the ignition is on and the motor is not running, both the signals work with the normal flash pattern. When I am riding the bike, the left blinker will work sometimes and the right once in a while, but most of the time it does not work at all. When I go to turn the right signal on with the brights on, I can see the bright indicator dim a little bit and it does not dim when I turn on the left signal. WTF is going on? Any suggestions?
Not to be a dick...
