Originally Posted by Millwright86
That sucks that this is happening to you.
Don't look now but I'm betting it's happening to you too
and every other Fury owner.
From the pictures I looked at it seams that all the "corrosion" is only on the welded seams, which makes me think that they never cleaned the welds from factory.
It's only in the vicinity of the welded seams but the welds are 'clean'. I expect they are robotic inert gas welds. I'm thinking the metallurgy of the adjacent metal is altered by the weld/heat which affects the adhesion of the internal coating in a 1" path on either side of the welded seam.
Just look at the quality of the outside of the welds on the bottom of your tank. Possibly some physical metal 'cleaning' treatment on the inside of the tank would help but you can't get inside once the tank is welded together. Or maybe there is a chemical treatment that would have done the job before the tank 'liner' coating was applied but I'm thinking not likely if the metallurgy has been altered. But all that is irrelevant now. The best we can do is filter out the sediment before it reaches the pump and injectors and routinely clean the reservoir as needed.
