Originally Posted by DeadSpider
After I was done and ate breakfast I drained my catch pan into a jug for recycling and found extra parts woohoo!
Hope you put on a new one, that would be the crush washer from one of the drain plugs (there are 2 fyi for those that have not done an oil change)
Originally Posted by Deanohh
Those stamped out round ones are no good because when the filter is tight, the flats of the filter deflect and the "wrench" just slips around.
I use these every day, did 4 oil changes this morning, and they work perfectly on the OEM filters, and I have had to hit some with a persuader to get the filter off. The filter should not be torqued that tight.
Originally Posted by Seņor Gar
This won't fit on my ABS Fury since I only have 3/8" end clearance  (filter to charcoal canister). How much clearance do you have Ben ?
That is why you need the one I posted, they were made initially for the Goldwings (the manual says to remove the front lower cowl to get filter off), this wrench slips right in.
