08-04-2010, 03:54 PM
#21 (permalink)
Originally Posted by Clueless
Hope you put on a new one, that would be the crush washer from one of the drain plugs (there are 2 fyi for those that have not done an oil change)
Damn....I was hoping it was a freebie washer from wallmart for buying their cheapest oil catch pan  Guess I am going to have to figure out which one is missing it and make a mess trying not to waste that damn $11qt oil :/
08-04-2010, 03:55 PM
#22 (permalink)
If you did not buy the bike in California (50 state model), there is no canister. The canister only comes on 50 state models, (all ABS models, and all matte silver are 50 state models).
Ok then I have the 50 state model
08-04-2010, 04:11 PM
#23 (permalink)
But inquiring minds want to know if you found which squish washer is missing, the front or the rear?
... Tony has left the building...
08-04-2010, 04:59 PM
#24 (permalink)
It was indeed the front one.
*NOTE*
Foot peg does not give way to skull
08-04-2010, 05:16 PM
#25 (permalink)
Originally Posted by Seņor Gar
The 2-1/2" Honda MC filter with round 'O-ring' gasket asks for 24-30 NM per inst on the filter.
BTW, I have never seen a mechanic use a torque wrench on a filter  .
Regardless, either filter definitely should not be installed more than hand tight.
OK I should have used the words "screwed on" instead of torque.
08-05-2010, 08:32 PM
#26 (permalink)
While changing my oil for the first time this past weekend, I encountered some extra parts on my bike not mentioned or shown in the photos from the manual. There is a canister mounted directly in front of the oil filter which made removing the filter impossible until I unmounted this canister. I was then able to get the filter replaced but I'm curious what this canister is for and why it is not pictured in the Honda manual.
It looks to be a fuel overflow capture or something but before digging around I figure I would ask here first. This is a CA bike by the way, so perhaps it is something added to bikes here to meet some state specific requirements?
08-05-2010, 09:01 PM
#27 (permalink)
From what I gather and post from Clueless above... it's the Charcoal Canister on the CA Model
Also Seņor Gar says its there on the ABS Model aswell
08-05-2010, 09:23 PM
#28 (permalink)
It is the charcoal can, fuel vapor from the tank is routed into it where it is absorbed and stored while the engine is stopped. When the engine is running, the purge control valve opens the vapors are drawn into the engine thru the intake manifold. . CARB requirement. Did you mean behind the filter, as in toward the rear of the bike ?
08-06-2010, 02:00 AM
#29 (permalink)
Originally Posted by djdiscman
I've attached the pages from the service manual for the valves and oil change.
Don't ignore the valves! You may be tempted to try to save time/money by only doing the oil change for the 600 mile service. Don't do it! When I did mine, two of my valves needed adjusting. One intake valve was super tight.
It's up to you whether you want to do the valves yourself or have the dealer do them for you. But you should know that the dealer will charge you a ridiculously high amount for a relatively cheap and easy job. A feeler gauge only costs a couple bucks at an auto-parts store.
I adjusted my valves at 500 miles and changed the oil at 600 miles. In case you are wondering why I didn't do the oil change at the same time as the valves... Particles may have got into the engine during the valve adjustment. I wanted to let any possible particles work their way to the oil filter before the oil change. If you have the dealership do the work, doing it this way and bringing your bike in twice may cost you some extra cash. If you aren't confident enough to do your own valves, consider at least changing the oil yourself.
my good man, you have inspired me thusly: this weekend I shall purchase by any means, all the necessary parts and liquids with which to mollify the oil-cravings of my baby.
sir, you do Rock, sir.
08-06-2010, 06:04 AM
#30 (permalink)
this actually worked and worked well for me......
REAL MEN SMOKE RUBBER
