The dampening adjuster is different than that spring adjuster, to adjust the spring you just pop off the right side cover and adjust the spring by twisting the knob, that adjustment is the one that helps stiffen up the suspension to keep the bike from sagging to much when you turn or ride two up, the dampner is that screw that's at the bottom of the shock and to my understanding helps soften or harden the rate at which the shock extends and retracts when going over bumps and potholes. Regardless of the adjustments you do if you take right turns aggressively and have certain pipes on the bike you are going to rub, I have the Morton Inferno's and rub on right hand turns just like people with the Swepts do, I just learned to slow down on those right turns.
