Be Careful RT Turns with Cobra Swept Pipes! - Honda Fury Forums: Honda Chopper Forum
Old 04-23-2010, 11:12 AM   #1 (permalink)
Default Be Careful RT Turns with Cobra Swept Pipes!
If you lean to far into a right hand curve the pipe hits the ground before the foot peg feeler does!
Found that out yesterday.
Called Cobra and asked if they were aware of that and they said "No, and it's $178.95 plus shipping to replace the chrome cover."
No, "We're sorry we designed a pipe that hits before the peg and we will replace the cover" or even offer a discount for replacement, NOTHING but "Good Luck and don't lean it so far".
Thanks Cobra!
You can see the peg feeler has no marks.
Doug
machine3 is offline   Reply With Quote
Old 04-23-2010, 11:14 AM   #2 (permalink)
Led Sled's Avatar
Bummer!
Led Sled is online now   Reply With Quote
Old 04-23-2010, 11:15 AM   #3 (permalink)
Led Sled's Avatar
Bummer! Expensive right corner/turn!
Old 04-23-2010, 11:36 AM   #4 (permalink)
I was on a clover leaf getting off a highway, surprised me that the pipe hit first!
Old 04-23-2010, 11:40 AM   #5 (permalink)
JimmyFarris's Avatar
Machine....That sux........
I just had my Swepts installed yesterday. What's the "fix" in your opinion? Shall we "extend" the peg a tad (pretty easy to do I think) so it scrapes first? Just a thought.
JimmyFarris is online now   Reply With Quote
Old 04-23-2010, 11:43 AM   #6 (permalink)
BarFury's Avatar
Tighten-up your rear suspension spring and lose about 50 pounds! LOL. Just kiddin', Jimmy.
BarFury is offline   Reply With Quote
Old 04-23-2010, 11:57 AM   #7 (permalink)
I have the accutroxix forward controls which are raised higher than stock (allowing MORE lean) and I only managed to rub the lower rear tip of the cobra but it wasn't noticable. I've never rubbed where you did and this is my first NON sportsbike where I leaned till my knee rubbed so this is odd. I'll keep my eye on it next week when we here MAY be able to ride again.
Snuffdog76 is offline   Reply With Quote
Old 04-23-2010, 11:58 AM   #8 (permalink)
Either enough of us complain to Cobra about pipes hitting and they fix the problem or yea extend the peg feeler. Not sure how much it would need, all depends on how far the suspension is compressed in a corner. Maybe half inch or maybe more. We need some people to do some testing.
Old 04-23-2010, 12:01 PM   #9 (permalink)
It all depends on how much the suspension is compressed in the corner. The cloverleaf I was on was a uphill turn so it was probably compressed a good bit.
Also depends if it's off-camber also. There's a lot of variables.
Old 04-23-2010, 12:12 PM   #10 (permalink)
Dave Maher's Avatar
Send a message via AIM to Dave Maher
I would assume this condition would be get worse once the lowering shock has been installed or am I wrong?
Dave Maher is offline   Reply With Quote
