wiring crossover - Honda Fury Forums: Honda Chopper Forum
 4Likes
  • 1 Post By EvoMotors
  • 1 Post By Kbuskill
  • 1 Post By hb_fury
post #1 of 7 (permalink) Old 09-13-2015, 08:21 PM Thread Starter
Metalcutter42's Avatar
Question wiring crossover
I want to adapt a turn signal mirror that is only made for Harleys to my fury.
The mechanical fitment is no problem.
What I cant figure out is these LED turn signals only have one wire.
Is there a way to wire it up to our system ?
C&C SportTour, Ginz Hellbent hc, Arlen Ness grips, R/axle cap mod, Custom fender relocation brackets, RWD mirrors with custom adapters, Custom 4” fork ext., STG 2into1, Velociraptor/custom trim ring, Reflash, DLX 3" forwards, custom 2" bar risers...
Metalcutter42 is offline
post #2 of 7 (permalink) Old 09-13-2015, 08:34 PM
EvoMotors's Avatar
Garage
Should be no problem if you want to use for turn signals only. To use as running lights / turn signals you'll need to use Blinker Genie for Run and Turn with LED Signals on Motorcycles ? Custom LED
Will'sFury likes this.
EvoMotors is offline
post #3 of 7 (permalink) Old 09-13-2015, 10:15 PM
Kbuskill's Avatar
Or you can make your own like this :
Dual Circuit Element « Bareass Choppers Motorcycle Tech Pages
Its simple, easy, and cheap... Just buy an LED compatible flasher relay to slow the flash rate back to normal. You can buy one that is direct plug and play for about $25 from chromeglow I believe or you can buy one like I did and wire it yourself... I bought an EP34 flasher (make sure it says LED compatible) for $12 at Advance Auto Parts... Our stock flasher is 2 prong and the EP34 is 3 prong so just run the 3rd prong to the ground under the seat... My 2 cents... YMMV
Kbuskill is online now
post #4 of 7 (permalink) Old 09-14-2015, 12:36 AM
hb_fury's Avatar
Garage
I posted a thread on this board in the DIY section on how to build your own diode circuits for this.
2 Wire LED Turn Signal Circuit (Running & Turn Signal Circuit)
It's not the life you choose, it's the life you live...
aka.. Tony_Fury
http://www.furyforums.com/forum/signaturepics/sigpic32929_1.gif
hb_fury is offline
post #5 of 7 (permalink) Old 09-14-2015, 01:06 PM Thread Starter
I will be the first to admit that I have NO knowledge about wiring.
That said, none of these solutions seem to fit the case. They all reference 2 wire bulbs/LEDs. This has a single wire coming from it. I am assuming it must ground on the body/stud of the light itself.
Maybe I am just misreading it.
Can anyone clarify how to make this work?
post #6 of 7 (permalink) Old 09-14-2015, 01:32 PM
Will'sFury's Avatar
There maybe 2 wires inside of that insulation or 3 or 4
The post could be a ground
Will'sFury is offline
post #7 of 7 (permalink) Old 09-14-2015, 01:53 PM
EvoMotors's Avatar
Garage
Negative is the frame of the motorcycle, when you install the mirror, the bolt with touch the frame. The one wire is positive + . You can test it by applying fastening mirror bolt to the negative battery terminal and wire to the positive.
this will work on Fury as on the fury negative is also on the frame.
Human Verification
