Clutch cable adjustment question - Honda Fury Forums: Honda Chopper Forum
Old 06-30-2011, 09:20 AM   #1 (permalink)
Exredninjaguy's Avatar
Default Clutch cable adjustment question
I changed out my levers (To Kury Zombies). Pretty straightforward, but now the bike must be in Nuetral to start. If in gear and I pull the clutch in, it won't start. Do I need to adjust the cable out more (turn nut away from lever) or is it something else? I have it turned out pretty far right now, and there's not a lot of slop on the lever. Can anyone explain this to me?
Thanks!
<img src=http://img.photobucket.com/albums/v645/grcelica/matter_of_life_and_death_16.jpg border=0 alt= />
Old 06-30-2011, 09:35 AM   #2 (permalink)
eva350's Avatar
Check out this thread. I had a different issue when I changed my levers, but I feel this thread will help you out. Forum members here are great
high RPM loss of power
eva350 is offline   Reply With Quote
Old 06-30-2011, 09:41 AM   #3 (permalink)
LesterDiamond's Avatar
There is a switch inside the clutch perch that only allows the bike to start in gear if the clutch lever is pulled. I had the same problems when I put in my levers. After replacing my perch, i pulled the sensor out as far as I could. Sometimes I have to pull the lever in twice to start in gear.
It's no big deal for me, as I usually put it in N anyway and idle while I get my chit together.
LesterDiamond is offline   Reply With Quote
Old 06-30-2011, 09:47 AM   #4 (permalink)
Ah that makes perfect sense!
Old 06-30-2011, 10:49 AM   #5 (permalink)
dragboat's Avatar
Book calls for only 1/8 inch free play. I gave mine a little more because if I had to stay on the clutch much in town seem like it would get hot and when I pulled the clutch lever in it wanted to keep crawling forward.
It be meeeez
January 2011 FOTM
dragboat is offline   Reply With Quote
Old 11-25-2012, 05:36 PM   #6 (permalink)
SECUREST's Avatar
Dragboat. You mean you gave it less free play because it was creeping?
"When your with me, it's not a trip, it's an Adventure."
Look up fury videos on youtube as drivercam
SECUREST is offline   Reply With Quote
Old 01-09-2013, 08:31 AM   #7 (permalink)
Originally Posted by farnk125 View Post
for adjustment of clutch cable you must open clutch perch then you make change in clutch setting.
I don't know what bike you are referring to, but with a Honda Fury you DO NOT open any clutch perch, it has an adjustment knob at two places on the cable, one after it comes out of the clutch lever and another one at the end of the cable on the left side of the engine, might want to do a little more research.....
Old 01-09-2013, 02:06 PM   #8 (permalink)
Furious Brit's Avatar
He's a troll Ki'. This is the guy who "rode his friends Rainbow" motorcycle(his words) in the thread riding through rainbows. He dosn't understand what we talk about and makes it up as he goes. Waster
Winston Churchill
Old 01-09-2013, 02:30 PM   #9 (permalink)
BAD BLUE 2010's Avatar
Gotta say it,WTF!!! Ex, just back the nut out till the free play is 1/8 or less, and you're good to go.
BAD BLUE 2010 is online now   Reply With Quote
Old 01-09-2013, 09:42 PM   #10 (permalink)
Guys, it's electrical; the switch in the perch and nothing to do with mechanical free-play adjustment .
Seņor Gar is offline   Reply With Quote
