Stalled again what luck! - Page 35 - Honda Fury Forums: Honda Chopper Forum
Old 12-10-2012, 01:32 PM   #341 (permalink)
endres1979's Avatar
Default Fuel
I had this exact same problem and searched the forum for many possible solutions. I took my concerns to a local motorcycle shop and he told me to start with the simplest thing and work my way up. I was ready to replace all kinds of stuff and he said it was probably just bad fuel and told me start there. Sure enough, syphoned out the old stuff, put some new gas in and have not had the same problem since. I was putting the high grade fuel in and he said that was a waste of money. He also made a valid point that the premium fuel is not used as often and sits in the tanks longer, giving it potential to go bad.
endres1979 is offline   Reply With Quote
Old 12-10-2012, 04:32 PM   #342 (permalink)
woodenhorse's Avatar
I agree, start with the simplest and work up...that's exactly what I did. I tried everything, change of gas, cleaning tank, filling tank different levels, re-routing the breather tube, testing it out in heat and sitting on side of road many times, had Steveo test his bike out in sweltering heat, checked controls, filtered fuel prior to filling tank, tested it in direct ambient sunlight vs. shaded light, tested it hot, tested it cold, bike would sputter and die when sitting in hot sunlight, would run ok when engine was cooled down completely..had to sit out some pgr missions cause it acted up, spent the whole summer testing.......conclusion, bad fuel pump and crap peeling from inside the pump. Changed the pump and no problems since.
BTW, I pulled my pump out with the rear tire still attached and brought it through the top rather than from side, so no paint scratching....just had to disconnect and move the wiring on the right side of the frame under the seat to have room to pull pump out.
Last edited by woodenhorse; 12-10-2012 at 04:35 PM. Reason: diff way of getting pump out
Old 12-10-2012, 05:01 PM   #343 (permalink)
Steveo's Avatar
Yep, guess I was one of the lucky ones that didn't have fuel pump problems.
Still have that damn starting problem from time to time, but it's never left me stranded, or even left me sitting by the side of the road for any duration of time.
The one time I just absolutely could not get it to start, I put it in 3rd gear and manually turned the engine over by rolling the bike back and she started right up. Don't know if it was coincidence or if it actually helped because I've only done that once. Since then, it eventually starts when the problem occurs without manually turning the engine.
Steveo is offline   Reply With Quote
Old 12-10-2012, 05:07 PM   #344 (permalink)
mine has hard start problem.....don't get a shorai battery, it makes it worse
Old 12-10-2012, 05:18 PM   #345 (permalink)
StPeteAPB's Avatar
I'm monitoring this to see if (a) this happens to you, again, Bob, and (b) if it happens to me, at all.
I use ethanol-free gasoline 99% of the time in my bike. I'm wondering if the ethanol-based fuels are causing the sedement issues in the fuel pumps.
August 2012 Fury Photo of the Month
Old 12-10-2012, 05:37 PM   #346 (permalink)
Could be Alan........been running the heck out of my bike......pipes are blue/black down to the first lower bend I've never had ethanol free in it....I really don't understand why they force that on us.....there is one station near my work that has the ethanol free gas.........more expensive, but may have to give it a go......my bike might go into permanent arrest!!!!!!
Old 12-11-2012, 08:12 AM   #347 (permalink)
I run eth free gas 90 octain 99% of the time.Never had a fuel related problem yet,knock on wood,lol.I beleive some of that white stuff in everyones filters is corn.Corn was made to drink,not burn.
Old 12-11-2012, 09:41 AM   #348 (permalink)
ROTFLOL....and here I've been eating it instead.............
