big CLUNK when shifting from N to 1? - Honda Fury Forums: Honda Chopper Forum
 17Likes
post #1 of 20 (permalink) Old 04-20-2017, 08:35 AM Thread Starter
Garage
My bike seems to SLAM or almost have s small grind when I go from neutral to first.
How normal is this? It isn't like a you aren't using a clutch just grinding it into gear, but its definitely a CLUNK that sometimes has an almost grindy sound to it.
The clutch adjustment feels fine, engagement is smooth and the pull is linear. Not too much play in the lever.
The bike has 600 miles on it right now.
WI_Hedgehog likes this.
Wrathchild is offline
post #2 of 20 (permalink) Old 04-20-2017, 09:20 AM
Goat's Avatar
Sounds normal to me. Mine has done that from day one and it has several thousand miles on it.
http://www.furyforums.com/forum/members/116x150x1398-steveo-albums387-crap-picture46321t-untitled.png.pagespeed.ic.7USV2JNVIZ.jpg
Goat is online now
post #3 of 20 (permalink) Old 04-20-2017, 09:48 AM
bigduke's Avatar
Mine does it sporadically. Im used to it.
bigduke is online now
post #4 of 20 (permalink) Old 04-20-2017, 11:32 AM
Originally Posted by WI_Hedgehog View Post
There's a thread about the clutch pack not getting enough oil, and a member drilling oil feed holes into the outer cage, similar to race bikes that have the same problem. I noted the Honda dealer warned me to watch the type of oil used or there would be clutch problems, and it didn't seem he was trying to up-sell me.
That is a different problem than the OP is having.
OP has a smooth release and engagment, but shifting into gear is the issue
My engagement was not smooth...but shifting into gear was fine. It was when I released the clutch lever it would engage, "BANG" and buck and lurch the bike forward.
krashDH is online now
post #5 of 20 (permalink) Old 04-20-2017, 12:25 PM
835
835's Avatar
Change the oil... I noticed the same thing and it got better after changing the oil.
835
835 is online now
post #6 of 20 (permalink) Old 04-20-2017, 01:26 PM
835
835's Avatar
What I noticed more was it got harder to hit neutral. That was never that hard anyways. Just harder.
835
835 is online now
post #7 of 20 (permalink) Old 04-20-2017, 01:28 PM
It's a bit more difficult to hit neutral from a dead stop. You have to give 'er yet finesse it once she starts to go so you don't just blow by it.
I've made it a practice to shift into neutral while rolling. It's butter if you do it that way.
post #8 of 20 (permalink) Old 04-20-2017, 01:35 PM
Septuagenarian Rider
Location: West End of the 49th Parallel on a US 2010-ABS/LB-Fury
Try margarine
Rope and WI_Hedgehog like this.
<pics<>links> *V-Mod * Factory X Forwards * Bagger Convertible
With a C&C seat, Xtended Forwards and Cannella Risers, 500 mile days are a breeze .
Seņor Gar is online now
post #9 of 20 (permalink) Old 04-20-2017, 01:40 PM
NORMAL especially when cold
Try freeing the 'stickiness' of the clutch by rolling the bike in 1st, clutch lever pulled in, before you start the engine. This should make the shift to 1st less severe. Or you could start in gear but that is harder on the starter and battery because motorcycle multiplate wet clutches always drag a little especially cold when the oil is more viscous.
post #10 of 20 (permalink) Old 04-20-2017, 01:56 PM
Tknj99's Avatar
Garage
Normal.. what i have gotten accustomed to doing is holding in the clutch while I roll down my driveway and then when on the street i click into first and its as smooth as butter...
Tknj99 is online now
Human Verification
