Looking for answers - Honda Fury Forums: Honda Chopper Forum
Old 11-28-2011, 02:57 AM   #1 (permalink)
vincentsfury's Avatar
Default Looking for answers
Does anybody with the honda lower chin scoop,that has the LED's in it.Know if there is a fuse or fuse box for the lights? Twice I've had the lights go out and Maxim honda has taken care of the problem.I would like to try to do it myself if there is a way to do so.Without spending money renting one of their mechanics.
SoberNSane
vincentsfury is offline   Reply With Quote
Old 11-28-2011, 04:23 AM   #2 (permalink)
I have removed my chin spoiler and know that there are connectors that are a pita to work with as for a fuse not really sure ya would have to check in the fuse block.
fury107 is offline   Reply With Quote
Old 11-28-2011, 04:31 AM   #3 (permalink)
Sludge's Avatar
Yes there is a fuse in the fuse box under the seat .
it shoul be the last one that is marked (OP) on the same bank as the fuel cut relay and the eng stop relay.
AND PROUD OF IT
Sludge is offline   Reply With Quote
Old 11-28-2011, 10:16 AM   #4 (permalink)
EvoMotors's Avatar
Fuses should not go bad so often, in fact they should not go bad at all. You may have a short in the LED wiring that you have to fix better sooner then later.
EvoMotors is online now   Reply With Quote
Old 11-28-2011, 11:58 AM   #5 (permalink)
Thanks guys,I'll check the box first.
MUCH APPRICIATED!
SoberNSane
