Originally Posted by fury107
i finally figured it out. it turns out after everything i replaced it turns out the ballistic battery i bought is bad inside. i guess it has a loose contact or something. so after like $500 dumped in parts its the brand new battery. oh well guess i have a few spare parts now lol.
After reading this entire thread, I think someone should write a STICKY in the DIY area that says, first and foremost, if something has recently started going awry,
what changed?
Though I work with software, it's can be the same situation in hardware.
When I have a customer who calls on Monday that things are not working properly but everything was fine before they left and closed shop on Friday ... I ask, "what changed?"
Often I hear, "nothing at all", which is usually BS.
In this case, and I'm not trying to rub $alt in your $500 wound, the battery was changed and wound up being the culprit. Who'd have thought? ... I know. But, I had a similar issue in the 80s with two bad new alternators, in a row, 'til I got one from a different batch that wound up testing properly.
Maybe write a letter to the manufacturer of the battery and share with them all the pain$ you went thru thinking, "it surely can't be the battery." Maybe they'll throw you a small gesture of appreciation of your business by sending you a battery charger (you'll have to round-about ask for it in your letter). Just a thought.
