Pair block off plates installed
put the block off plates on today and didnt have to remove the tank, took a bit longer but I didnt want to take the tank off used a long 8mm wrench from the opisite side on the rear one. also noticed a rattle comming from the cover on the left side where the coolant reseve is if you tap on the top of the case u will hear it rattle took some sticky weather stripping foam and put on the inside of the cover at the top where the groment holder is took care of that rattle.
Regards,
Dewking: dam plastic head covers
 DAM Plastic Head Covers
