Seat mod for Sumo kit. - Honda Fury Forums: Honda Chopper Forum
Old 11-02-2012, 06:49 PM   #1 (permalink)
TacOBruiseR's Avatar
Default Seat mod for Sumo kit.
Has anyone tried to modify a Danny Gray Buttcrack to fit on the Sumo X???
Sent from my DROID RAZR using Motorcycle.com Free App
"ZOMB3" Aug. 2012 Fury of the Month
Sumo X kit, Platinum air ride, DLX Grips & Pegs, Billet Blade Levers, Spike Intake, PCV, Raw Designs Blades, MFR 3" Forwards and Pipe. 23" front wheel, 10* trees
TacOBruiseR is online now   Reply With Quote
Old 11-10-2012, 03:23 PM   #2 (permalink)
I'll answer my own question,,,,, yes it does, but it is a bitch to do! The seat cover is not stretched tight in the pics. I will finish it tomorrow and post pics.
Old 11-11-2012, 10:32 AM   #3 (permalink)
So did you have to modify the bottom of the seat. I had to cut two sections of the bottom of the seat and then make some small bend cuts at the rear so my c&c seat would fit. But yours looks way better than mine. Can you take some pics and dirrections of what you did. I may just buy a seat like yours.
ALEYRAY is online now   Reply With Quote
Old 11-11-2012, 12:37 PM   #4 (permalink)
Ya, I had to grind through the seat pan in a few spots. A bunch of trimming and shaping. If I was buying a seat, I would contact abonnet about getting a seat pan and build it myself. I actually thought I trashed my seat. It wasn't looking good or that it would even work. I just kept messing with it till I got it decent looking. Hopefully I can put up some pics tonight when it's finished!
Old 11-11-2012, 01:36 PM   #5 (permalink)
OBSIDIAN's Avatar
I concur. My stock seat is also high and i plan to grind the bottom of the pan to clear the new fender. Maybe a note should be included in the video. Its nice to know we all have the same issue, must be normal.
Sent from my DROID RAZR using a carving knife and a grinder.
OBSIDIAN is online now   Reply With Quote
Old 11-11-2012, 06:08 PM   #6 (permalink)
well i think u did a great job as far as fitting it. i dont know how it looks at the bottom but the top looks good. lol
Old 11-11-2012, 07:29 PM   #7 (permalink)
I circled all the areas that had to be ground down. I f'd up when I made my initial cuts. I didn't take account for the amount of rotation the seat would have, so I gorilla glued 2 small parts of foam I cut off back on and shaped and blended them in before I buttoned it up.
Old 11-11-2012, 07:31 PM   #8 (permalink)
I took a lot of material off of the sides as well. All I can say is WAY COMFY!!!!!!!
Old 11-11-2012, 07:43 PM   #9 (permalink)
maybe i can buy a seat like yours and send it to you for modification.
are you up for the challange? of course for a charge.
