High & low beam light issue question
Hello Folks!
I am having an issue with my high and low beam lights and would like to if any of you folks have experience this problem before and know what can be the problem.
I have an HID kit on my Fury which has worked flawlessly for 2-yrs but for some reason it has gotten stucked either on the high or the low beam position and when I hit the switch on the handle bar to change it from high to low beam, it simply won't change, it just stays stuck on what it seams to be the low beam position. When you hit the switch to the high beam position, the blue light on the speedometer dashboard turns to blue the way it should be, but the headlight remains on the low beam position. i checked the fuse for the headlight and it is okay. One thing that I do on a regular basis. is to wash my bike bi-weekly, so I don't know if humidity or water could have play a roll on this, but then again, I been doing it for two years and never had an issue, so I don't think that water had anything to do with this problem.
I remember that when I use to have my VTX-1300C, issues of this sort use to be sort of a common thing with those bike models with the light switch, water and dirt use to create a coating film od dirt on the switch contacts that would prevent the lights to work properly, so people use to bring the switch apart and clean them with electric contact cleaner and the problem would go away.
Have any of you experienced the same problem I am having?
Thanks in advance for your assistance on this matter.
