SH!TING BRICKS - Honda Fury Forums: Honda Chopper Forum
Old 12-02-2012, 02:14 PM   #1 (permalink)
bruin's Avatar
Default SH!TING BRICKS
So
I got myself a side mount plate, NOW I am not too sure how to remove the original plate stuff from the bike. I am not in the money to be going stealth and kinda like the look of the original tail light...Problem is that I am not sure what is the best way to cut off the plate mount and plastic "stuff"
Obviously any and every tidbit of help is appreciated. I know guys on here have done it as I have seen pics with them done, just would like to hear from the DIY's before I ruin it!
Thanks
bruin is online now   Reply With Quote
Old 12-02-2012, 02:51 PM   #2 (permalink)
DaveRed's Avatar
Hey Bruin, I started by removing the reflector and plastic t section , used an aluminum plate 1" x width of plate and resecured plate and moved the L plate up under L plate light snug.
I started to remove the L P light to move up further , then decided to go with the stealth,
Old 12-02-2012, 02:55 PM   #3 (permalink)
bruin's Avatar
Default ;o)
I am talking about removing all of that including the light and only having the taillight...no plate light at all. But from what I see I have to cut the light out...Yours looks nice and clean to me. How do you like the stealth. Is it worth the $$$. any electrical issues?
Old 12-02-2012, 02:58 PM   #4 (permalink)
bruin's Avatar
Default ;o)
Do you have an after shot with the stealth on there so I can compare. I really like the clean look of what you originally had set up there. I would like to see a stealth from a closeu POV and its extra nice to see a bike the same colour as mine :O)
Old 12-02-2012, 03:00 PM   #5 (permalink)
DaveRed's Avatar
Still waiting for delivery of the stealth,
I can take pics and post when I get home of the LP light cuts I made to the plastic, I could trade u the metal bracket which I have already cut and had rewelded , I will be in touch
Dave
Old 12-02-2012, 03:02 PM   #6 (permalink)
DaveRed's Avatar
There is a recent post regarding stealth install with pics, leaving work now
TTYL
Old 12-02-2012, 03:04 PM   #7 (permalink)
bruin's Avatar
Default ;o)
I appreciate the trade offer, but I purchased a sidemount plate thingy. i will take you up on those pics of how you cut the plastics though. I assume you did the black friday buy on the stealth...can you hear that noise, yeah thats me kicking myself- CR@P
Old 12-02-2012, 04:38 PM   #8 (permalink)
DaveRed's Avatar
The LP light removed, I was going to place LP to the top of it and use led bolts I found @ the bike store to illuminate .SH!TING BRICKS-imageuploadedbymotorcycle1354484142.672322.jpg
A member posted this next pic , he used epoxy to fill signal holes and rebuild removed LP light mount for a clean finish, sanded and reprinted,SH!TING BRICKS-imageuploadedbymotorcycle1354484254.201906.jpg
Old 12-02-2012, 04:40 PM   #9 (permalink)
DaveRed's Avatar
I used a dremel with a 1" diamond disk to trim plastic , hacksaw works , deburr , good to go ,
Old 12-02-2012, 04:53 PM   #10 (permalink)
White lighting's Avatar
I removed seat ,fender, took the whole beaver tail off and cut it down right underneath license plate light put reflector in hole and ran license plate light wired own to side mount
White lighting is online now   Reply With Quote
