This image of the removed exhaust side harness connectors should confirm the location of the relative position of the male pins/wires in the remaining main harness connectors that need to be shorted with the 330 Ω resistor. Alternatively, you could order this plug-in solution form eBay. Just click on the image
. Note: These plastic connectors are the reverse of the US version and will not work on NA O2 equipped Honda motorcycles as noted by
macXpert.
