12-30-2012, 12:44 PM
#11 (permalink)
Originally Posted by BAD BLUE 2010
StPete, Thanks Bro, I will order one today. And I wasn't sure about the indicators being lit dimly, didn't think it was gonna hurt anything. So yeah I'm just gonna let it go as is. But will get the relay. Thanks.
If you do go with the BBP 13-306 relay, you can search a thread here under "turn signals" by habadir......it has some more info on the wiring configuration of the relay. I've had this unit a couple years now and it works great. If any questions, just post or PM
ctc6698
March 2012 Fury Of the Month
12-30-2012, 02:07 PM
#12 (permalink)
Thanks Phil, I can even get advise from across the pond!! how cool is this forum!!
No problem bro.
Ride safe
Sent from my GT-S5830 using Motorcycle.com Free App
12-30-2012, 02:31 PM
#13 (permalink)
Looks like all you will need is a new relay Furious Brit. Hope this helps us both!!
Sincerely, Thanks for starting this thread Blue. And thanks to everyone for the valuable info, let me know how you get on with yours buddy.
Ride safe mate
Winston Churchill
12-30-2012, 06:42 PM
#14 (permalink)
Ride safe mate
Thanks to all for the help! that's why this forum is so awesome!!
12-30-2012, 07:14 PM
#15 (permalink)
Ok, here's my blinker/LED question. My Fury came with the LED tail/stop/turn light, I am going to change the front lollipops to blades. Are there any mods I need to make to get them working correctly?
12-30-2012, 09:38 PM
#16 (permalink)
It would depend on if they used load equalizers for the rear or changed the relay then. If the relay is changed, you're fronts would be plug and play. If not, you'd then either need the relay or use L/E's for the front.....relay preferred.
01-04-2013, 11:47 AM
#17 (permalink)
Just ordered the BBP 13-306 relay. Needed it to solve the fast blink turn signals.
Always prefer plug and play over tapping into wires plus the load equalizer gets hot and you have to mount it somewhere.
BBP FTW. Thanks ctc6698.
01-04-2013, 03:15 PM
#18 (permalink)
Originally Posted by Dirty Harry
Harry put me on to this one (above) works a treat
Winston Churchill
01-04-2013, 03:37 PM
#19 (permalink)
Sheesh what a deal. I couldn't find that part in the states however  . Ill have the other part tomorrow.
01-08-2013, 05:45 AM
#20 (permalink)
If your rear lights are blinking at the correct rate, Blades should work fine. If not you'll need a load equalizer.
