12-29-2012, 04:47 PM
LED turn signals
Hey guys, I just replaced my turn signals with the bullet shape LED ones. Got them tucked in on the back and mounted under the headlight up front, with a couple of "L" brackets. Everything is hooked up and working, but I noticed the signal indicators on the dash are dimly lit and they blink fast. My question is, do I need a load ballast, or just a newer electronic relay to get the blinking back to normal.
12-29-2012, 07:38 PM
OK can somone explain for us stupid people.
I'm about to swop out my front and rear lollypops for these 1.1/2" X 1" LEDs
As i understand it, I will need 2 x resistors, one on each front turn signal, & a flasher can good for LED turn signals. Correct ?? or have I F*&%"D up.
HELP!
Winston Churchill
12-30-2012, 04:07 AM
Hi guys
When I fitted leds all round the Dragstar I just changed the flasher unit to a led compatible low output replacement.
Brought a Yamaha unit from ebay, straight swap and all sorted.
They did do units for other makes.
Ride safe
Sent from my GT-S5830 using Motorcycle.com Free App
12-30-2012, 05:28 AM
I,ll try that Phil. cheers mate.
Winston Churchill
12-30-2012, 07:55 AM
Originally Posted by Dirty Harry
Good man Harry. I'll go for that. Cheers mate
Winston Churchill
12-30-2012, 09:12 AM
The blinking fast is due to an imbalanced load between the front LEDs and the rear incandescent bulbs. A load balancer would solve the blinking issue, as would a replacement blinker relay:
Plug an play flasher for LED signals...
The slighly lit indicators ... I have that on my speedometer, as well, and I have the Kisan Tech SM-3 turn-signal cancellation (load equalizer, etc.) module on my bike. Just ignore that - it's of no harm.
12-30-2012, 12:19 PM
StPete, Thanks Bro, I will order one today. And I wasn't sure about the indicators being lit dimly, didn't think it was gonna hurt anything. So yeah I'm just gonna let it go as is. But will get the relay. Thanks.
12-30-2012, 12:21 PM
Attachment 15886
HELP!
Looks like all you will need is a new relay Furious Brit. Hope this helps us both!!
12-30-2012, 12:23 PM
Originally Posted by Phil ' Ferret ' Joseph
Hi guys
Ride safe
Thanks Phil, I can even get advise from across the pond!! how cool is this forum!!
