Originally Posted by OBSIDIAN
I have a Fury and a Sabre. The Fury rear wheel WILL NOT fit on a Sabre.
The Sabre swingarm does not allow clearance for the tire on the right side. You would have to put a Fury swingarm on a Sabre which nobody has ever done.
I know kind of late reply, but just saw original post.....
I'm currently working on this mod, while I don't have exact measurements yet nor have I put Fury wheel/tire up to Sabre yet, I agree with OBSIDIAN... Sabre swing arm will not allow clearance. It will need a small "tweak". Looking @ Fury wheel w/tire, the edge of the tire (width) is in line with brake disc mount surface. On the Sabre, follow line from rear disc to front inner right side of swing arm, there is small area that looks like will be interference.
Thinking it might be easier to modify Sabre swing arm. Not sure how Fury's alignment is.. Are Sabre & Fury frames the same in swing arm mount area ?
But what appears to be a bigger issue is the sub-frame. It will also require modification. Width of Fury tire is about 7-7/8". The Sabre sub-frame measures about 7-1/2" at then narrowest inner section (area where sub-frame mounts to main frame) and about 7-5/8" remainder of inner section. The outer section of the sub-frame is 9-1/2". So I'm planning to cut out the inner section of the frame tube and then reinforcing outer section by adding 3/16" plating, attaching at main frame as well. Overall cross section area of each frame arm will be same (or slightly more), just solid instead of tubing. Similar to T-Mod's "Sumo T-Mod", but keeping outer section of original frame rail to weld new support to. Will also do T-Mod at same time.
