Our manuals say to use Pro Honda HP Coolant or equivalent high quality ethylene glycol antifreeze containing corrosion protection inhibitors specifically formulated for use in aluminum engines with the added notice that using coolant with silicate inhibitors may cause premature wear of water pump seals or blockage of radiator passages.
I have a new jug of coolant that is JIS K-2234 standards compatible.
Does anyone know if this is the equivalent standard to Pro Honda HP coolant?
Thanks guys (and gals)!
