Originally Posted by taffyspop
Attachment 8986
Does anyone think these would work on the Fury? They clamp on the downtube. Would solve a lot of cruising problems if they would work. Don't know how far they would stick out or if they would stick out far enough. Dimensions not listed. What say you. They are from Kury and I found them after running a Fury search for pegs......
Hey there everyone,
They will work. The downtubes are 1.35mm and clamps are available from Kuryakyn. Those right angle pegs stick out about 10 inches give or take. I was able to work the clamps around the down tubes below the top of the radiator on both sides. If you are taller than 6 feet I don't think its going to give you enough leg room unless you don't mind resting the back of your boot on top of the peg.
The factory air filter cover sticks out way too far.
Im 6 feet tall and glad I bought these. I was resting my shoes on the brake and clutch on the highway.
