Battery charge indicator - Page 3 - Honda Fury Forums: Honda Chopper Forum
Old 10-28-2011, 01:30 PM   #21 (permalink)
Steveo's Avatar
Originally Posted by woodenhorse View Post
LOL!!!!! Thanks, hadn't thought of that! Where you going to put it? Dave Maher has his on his reservoir, but he's getting up there in years and senility has kicked in.....he forgot how it was wired....... Anyone else have any good ideas as to where to wire the indicator?
Wire it to your battery.
Steveo is online now   Reply With Quote
Old 10-28-2011, 02:24 PM   #22 (permalink)
woodenhorse's Avatar
Novel Idea!!!!!! I may end up doing that, but then will have to get some more wiring..........
Old 11-02-2011, 05:26 PM   #23 (permalink)
For those of you who have battery indicators, where did you tie in the wires? Also, if anyone has any suggestions as to where to tie the wires in, I'd appreciate it. I was thinking about trying to tie it to the front running lights and mount it on the brake reservoir. What do ya'll recommend?
Originally Posted by 2 Evil View Post
Not a good idea. I say this because I did that. When I use my right turn signal the indicator goes off until the signal is off. Something I need to rewire now lol. Mounting it on the brake res is pretty much the most convenient place to put it.
I think you are both on the right track . To avoid signal interruption hook up to the front running light supply wire (brown) in the 14 pin connector inside the headlamp shell.
Old 11-02-2011, 06:50 PM   #24 (permalink)
2 Evil's Avatar
Gar, You are the best! I will be working on that when I do my air horn. I knew someone would know where to hook it up. Thanks bro!
I bought this bike to ride not wash every weekend!!
2 Evil is online now   Reply With Quote
