I know some guys that once they see this, will freak out. Unfortunately, I've pushed as hard as I could for it to not come to this, but sometimes life takes a turn and other priorities arise. Such is life.
With that being said...
2010 Honda Fury (special edition) in matte grey/silver color. Honda made 500 bikes in this color, this is #110. This bike was brought brand new off the floor in May 2012.
This bike also comes with a transferable unlimited mileage 3 year warranty, on top of the 1 year from Honda. Full front to back and everything in between is covered, for a total of 4 years from May 2012.
This bike has always been garaged and taken care of, it is very clean through and through.
This bike gets so much attention from anyone and everyone, no matter where you are at. People at the gas station will ask you, people at intersections waiting on a red light will ask you. This bike makes onlookers drool, no question. If you don't believe me, ask anyone else that has a fury.
This bike is the best of both worlds, comfortable and amazing looking. I rode this bike straight from north Indy to Gatlinburg, TN in a single day without a hic-up, when everyone else couldn't keep up. Its been on the tail of the dragon, blue ridge parkway, and everywhere else in between. The length of this bike with the 1300cc engine gives it the stability and cruising power only matched by bikes twice the price.
Send me a private message on these forums. I'm located in Indianapolis, IN
Asking $11,000
4900 miles
The bike is completely stock besides:
Cobra chrome swept exhaust
LED wrapped turn signals
It does include a gun slinger style rear seat, it just happened to be removed while the pics were taken.
ENGINE
Engine Type 1312cc liquid-cooled 52 degrees V-twin
Bore And Stroke 89.5mm x 104.3mm
Induction PGM-FI with automatic enricher circuit, one 38mm throttle body
Ignition Digital with three-dimensional mapping, two spark plugs per cylinder
Compression Ratio 9.2:1
Valve Train SOHC; three valves per cylinder
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 45mm fork; 4.0 inches travel
Rear Suspension Single shock with adjustable rebound-damping and five-position spring-preload adjustability; 3.7 inches travel
Front Brake Single 336 mm disc with twin-piston caliper
Rear Brake Single 296 mm disc with single-piston caliper
Front Tire 90/90-21
Rear Tire 200/50-18
DIMENSIONS
Wheelbase 71.2 inches
Seat Height 26.9 inches
Curb Weight 663 pounds (Includes all standard equipment, required fluids and a full tank of fuel ready to ride)
Rake 32.0 degrees (Caster Angle)
Trail 92mm (3.6 inches)
Fuel Capacity 3.4 gallons
Miles Per Gallon 45 MPG*
