Mrbyber and Jay Cee have summarized it pretty well; anybody who thinks they're going to get a 15-to-25 H.P. increase from adding a second intake is delusional and needs to read-up on the concept of Volumetric Efficiency. None of the filters (including the stocker) that I've seen applied to the Fury are limiting the air-flow into the Fury engine, and neither is the cross-sectional area of the Throttle-Body. Look, instead, to the relatively-small-and-turbulence-inducing "T"-shaped Intake Tube, and/or the relatively small cross-sectional area of the Intake Ports, and/or the relatively mild (0º) Intake Cam timing. It is in these areas where increased Intake-Flow and increased Volumetric Efficiency are to be found. Anything else, you're just fooling yourself and pouring money down a sand-hole.
