Originally Posted by joefury
which side did the leds burn out? right throttle side or left kickstand side.
when my lights burned out it was on the left were probably water accumulated at the lowest part. only 5-6 leds were out. i took pictures and sent it to Radiantz they make the lights RAW uses. after they were replaced no problems since.
i believe 2Evil in NY had a great idea of opening the light tube and filling it with Diaelectric clear grease to avoid moisture build up.
The original one never burnt out, it had a bridge ground that connected the 2 sides and that came loose. If you squeezed the tube in the center it would come on. It was the kickstand side, which is the one that only has a red wire. The new one is a burnt diode that melted the tube. It's almost in the center. If it was, I would have just sealed it up and painted it black. Having a little gap between them doesnt look that bad.
