Fuel Gauge options? - Page 3 - Honda Fury Forums: Honda Chopper Forum
 19Likes
post #21 of 29 (permalink) Old 04-10-2019, 12:14 AM
Septuagenarian Rider
Señor Gar's Avatar
Location: West End of the 49th Parallel on a US 2010 CBS/ABS Fury
Originally Posted by decarmine View Post
So then I'll refill my tank, reset the odometer, and see what happens around 120 miles...
Some folks get the light at 100 miles, depends how hard you ride.
boatwire likes this.
Señor Gar is offline
post #22 of 29 (permalink) Old 04-10-2019, 10:57 AM
BakoFury's Avatar
Garage
Send a message via Yahoo to BakoFury
Any kind of fuse involved, Senor Gar? Maybe just a broken wire?
Insert clever phrase here that will garner respect and love.
Fury Nation Map
BakoFury is online now
post #23 of 29 (permalink) Old 04-10-2019, 11:21 AM
Señor Gar's Avatar
Remove the two sensor wires and connect with a jumper to see if the low fuel level light circuit is working properly
post #24 of 29 (permalink) Old 04-11-2019, 02:45 PM
SuperDutyTrooper's Avatar
Garage
There is a product called a "FuelGaugePro" available on eBay for about $159 (electronic bar version) or $179 (analog version). Or you can order it directly from the manufacturer, LSK Motorcycle Electronics, www.lskelectronics.com which is based in the Czech Republic.
This device says it "measures the hydrostatic pressure and computes the level of the fuel in the tank, or the actual amount of fuel – according to the mode you select. That enables even those with a motorcycle with no float in the fuel tank to have fuel gauge". It has a sending unit that mounts in-line with the fuel line to the pump, presumably under the tank.
I think someone should get one of these and let us know how/if it works!
Señor Gar likes this.
SuperDutyTrooper is online now
post #25 of 29 (permalink) Old 04-11-2019, 05:36 PM
Garage
Pull the tank off, Cut the wires. Now put the tank back on. Go for a ride. When you get to 100 miles start keeping your eyes open for a fuel station. Problem solved.
Rope and BakoFury like this.
Salty Hog was here on his Springer Fury and still here.
460brevill is offline
post #26 of 29 (permalink) Old 04-12-2019, 05:27 PM
WI_Hedgehog's Avatar
There's a plug on the bottom, just pull on them a bit and the warning light will go on. LOL
Maybe look at the 50 MPG thread. I've gotten something like 175 miles/tank.
Those delicate gauges don't usually last long, maybe to a Google search and see what others say.
-Sir Ironass
(Fury Nation map)(msg BakoFury your zipcode for add)
(Ginz Choppers - excellent service & prices)
WI_Hedgehog is online now
post #27 of 29 (permalink) Old 04-12-2019, 11:42 PM
JCB
JCB's Avatar
I'm tempted to do this...
BUT... a Fury tank is just too dang PRETTY!
I barely made it off the interstate and coasted up to a pump one time. So... I got one of these.
Fits into my sissybar bag for the long trips.
waynejitsu likes this.
"I'm never lost... I'm just somewhere I haven't been before."
JCB is offline
post #28 of 29 (permalink) Old 04-15-2019, 10:38 AM
Originally Posted by PAW View Post
Does anyone out there make a fuel gauge in a gas cap that'll fit the fury? I know many complanies make them for HD, but can't find any for us. (Motorcycle Gas Cap & Gauges | J&P Cycles)
As @X_KIOWA_X mentioned, there are no direct-fit aftermarket fuel cap options that we know of.
Because of the shape and angle of the tank a float will not work. The Fury uses a thermistor for the Fuel Reserve Sensor as @Ordinary Biker mentioned.
So... here's a question: I recently had my tank off to be painted. Tank was completely dry when I put it back on the bike. To test the "low fuel" light, I first put in maybe less than a quart of gas, turned on ignition, and started bike. Light did *not* come on. I subsequently filled the tank and have not driven enough to run low on fuel, but I'm not sure I now trust the light.
When I first bought the bike (used) there was little fuel in tank and light *did* come on, so I know the light worked at that time. I reconnected the wires when installing the tank, but paid no attention to which wire went on which lug. I just assumed it was an *on-off" switch.
So does the switch have to cycle through a "cool/warm" sequence?
Do I need to reverse the wires on the switch?
Has the switch somehow failed during the time (two months) it was off the bike and out of the tank?
The thermistor works immediately, there's no reset sequence to go through. The wires work either way, the thermal resistor does not have a polarity.
These threads address your issues:
No reserve light? Also, weird noise question
50 MPG !!!!
(Around page 5 there are actual fuel mileage calculations)
Regarding proper operation of the Reserve Indicator, please see the Service Manual, pages 22-17 & 22-18 (attached).
ID:	220144   Click image for larger version
ID:	220146   Click image for larger version
BakoFury and decarmine like this.
-Sir Ironass
post #29 of 29 (permalink) Old 04-15-2019, 02:51 PM
Originally Posted by WI_Hedgehog View Post
The Fury uses a thermistor for the Fuel Reserve Sensor <snip>
Thanks. You've answered all my questions...
Frank
WI_Hedgehog likes this.
decarmine is online now
Tags
gas , tank
