1 - 8 of 8 Posts
I need some help I put 4 quarts of oil in th bike with the new filter she will not show on th stick.
Nevermind, put bike upright and your good, Havent changed the oil in the bike as much as i have my car with 135k or my truck with 140k miles and those values default to my head.
i did mine last week, 3.8 qts with filter change. stand bike straight up n check, should be lil high, run motor sitting for five min, turn off, cool for five min. stand bike up straight and check again. and if lil high dnt worry, better a lil more, then not enough
You'Ve got all good advise here. The bike has to be upright position or you are going to get a false reading and you should also run the engine to circulate the oil the filter for a couple minutes then check it. If you put the oil in its not going to disappear and unless you see a oil puddle under the bike your good.
1 - 8 of 8 Posts
