1 - 20 of 128 Posts
This is a continuation of the original thread found here: http://www.furyforums.com/forum/honda-fury-sale/95922-2011-honda-fury-complete-part-out.html
I started a new thread so that I can update the post as items sell as per Brad's @WI_Hedgehog suggestion.
CONTINUED....
So I have started compiling a list of parts that will be available as soon as the paperwork is a cleared up with the insurance company. I think I have decided to just post up the list with prices instead of going the auction route... it just seems easier that way. I would prefer a text message or call if you are interested in any parts because it will be quicker and easier for me to get the messages without having to login here and check and clear my inbox. My number is (904) 704-8653 call or text with any questions or ask in this thread and I will answer as quickly as possible. These parts won't be available for at least a few weeks I am guessing. All parts prices are listed and DO NOT include shipping. When you contact me please include your screen name so I know who I am dealing with and your zip code so I can get you a price on shipping. Prices are negotiable but please remember I am currently out of work due to my wreck and I am trying to pay bills and put food on the table during this lengthy recovery process. There are some pics in my albums and if you need any more pics please don't hesitate to ask. So without further ado... here we go.
PayPal friends & family please.... I am not a business, just a guy trying to recoup some of his loss.... Thanks
1. K&N Filter for stock air box $25
5. Big/linked brake upgrade from ABS Fury includes:
3 piston front caliper W/ modified front caliper bracket and pads
2 piston rear caliper W/ caliper bracket and pads
Bigger rear master cylinder for the linked brakes
Proportioning valve for rear
Associated hoses/lines etc. To buy all these parts on bikebandit would cost around $1K
See pics in my albums.
Everything you need to bolt onto your bike EXCEPT the 2 front brake lines because the wrecker driver cut them when he picked up the bike to make it easier to separate the front end. This upgrade makes a huge difference in the way these bikes stop. $500
7.Sold... Thanks Turcoloco Home built "Platinum" bleed feed style air ride W/ "instant up" air tank. Kit includes:
1 dual action 3" X 2" air cylinder W/ custom made lower mounting bracket to attach to the swingarm and the stock upper mount.
1 air tank with a 180/200 psi pressure switch to turn the compressor on/off and all associated fittings, this is not even an option any where on the market.
1 Viair 275c air compressor which is an upgraded (bigger) compressor compared to the Platinum setup.
2 manual air ride toggle valves to lift/lower and increase/decrease rebound. In my opinion these are superior to electronic valves as there is less that can go wrong.
1/4" DOT air line rated at 300psi with a burst rating of 1200psi if my memory serves.
1 electric toggle switch to turn the compressor on/off manually.
1 ignition switch/tool box cover painted lacquer black with the toggle valves installed in the top and the electric toggle mounted in the original location of the ignition switch.
1 gutted tool box that the cover attaches to. This gives you clearance for the valves.
Check valves and associated hardware.
I will include a diagram to show the proper way to plumb everything if needed.
I built and have used this kit for about 2-2.5 years without any issues. The compressor seems a little noisier than before the wreck, it may just be from the bike sitting for the past 2 months but I wanted to mention it... worst case scenario is a new 275c compressor kit for $150.
You can see the new prices for an instant up kit here: AirFX Instant-Up Air Tank for AirFX Air Ride Suspension Systems - FXA-2012 - Phat Performance Parts ($350) and the price for a platinum kit here: https://platinumairsuspension.com/pr...dow-stateline/
($1080)
So new with warranty air ride + instant up kit* that you have to figure out how to fit = ($1430)
I would really like to see this go to someone with some technical/mechanical savy/inclination and I would also like to mention that I will in NO WAY be held responsible or liable for any damages or injury you or your bike may incur do to you purchasing and installing this. I have ridden with it for over 2 years without any issues so I don't foresee any problems but again I am not to blame if anything should happen. This kit is sold as is and will come with everything you need to bolt it up. The compressor has brackets welded onto it that will bolt to the lower transmission mount bolts with the longer bolts that I will include and the air tank is held in place under the bike with a big hose clamp. This setup requires slight clearancing of the frame under the seat to fit the air cylinder, please see my albums for a pic of what I am referring to or ask for more details. I would like to get $750 for this complete setup.
8. Black Rear wheel including brake rotor and Dunlop elite 3 200/50/18 tire with approximately 18k miles on it $300
9. Black Front wheel including brake rotor has a couple scratches near the outer edge with Dunlop elite 3 90/90/21 tire with approximately 6-7k miles. Does not appear to be bent. I can take it and have it checked $350
10. Complete frame without damage but a dead VIN (certificate of destruction) in the state of FL. The rear fender supports have had the modified T-mod done which drops the rear fender to get rid of the dirt bike look of the rear fender. This would be a good starting point for a custom build (cut the neck off and put harley neck cups on and apply for a home built or assembled from parts title). I saw straight frames without titles on eBay for $1500 and bent frames for $6-800 So with that being said shoot me an offer I can't refuse... if not she will go in the scrap pile.
12. Sold... Thanks Macxpert Two Ignition coils including spark plug wires. $50
15. Stock rider seat and passenger seat... make offer $???
17. Speedometer/gauge cluster with custom face plate. Odometer reads 18,080 miles. $200
18. Full set (front and rear) custom painted lacquer black engine head covers and matching lower left coolant tank cover.Just realized these got a couple scratches during the wreck... nothing cracked or broken. I can send pics if you are interested. $250... make reasonable offer???
19. Coolant overflow reservoir. $20
20. Stock black NON-ABS front and rear brake calipers and brackets including pads and rear master cylinder. $200
21. Stock muffler. Make offer $???
22. Black fuse box side cover $50
23. Stock black swingarm, ready to modify for a 250 tire. $300
24. Stock riders seat complete with brackets, perfect condition. Make offer $???
25. 2 stock passenger seats. Make offer $???
26. I also have a filler plate/panel that goes behind the clutch cover on the right side of the bike to fill in the gap. I bought this and never got around to installing it. I don't have any bolts or spacers to go with this so you will have to figure that out on your own. Make offer $???
27. US spec muffler that has the end plates drilled out to 1/2".... make offer $???
28. Stock muffler bracket which helps you maintain traction due to its weight. Make offer $???
29. Stock black triple trees. Scuff marks on upper tree. I removed the stock trees when I installed 8° trees and a member here needed the upper tree because his had scuff marks so we traded upper trees. Make offer $???
30. Stock Chrome air filter cover that has some very minor scratches. Make offer $???
31. A home made Black curved side mount tag bracket with brake light. It will come with the bolt that goes through the axle to mount it. Make offer $???
32. Link to pics of speedo and side mount tag bracket: http://www.furyforums.com/forum/1591498-post77.html
33. Link to pics of forward controls: http://www.furyforums.com/forum/1591514-post79.html
34. Link to pics of side covers and headlight ring in the other thread: http://www.furyforums.com/forum/1591538-post80.html battery side cover SOLD
35. Link to engine head covers: http://www.furyforums.com/forum/1591554-post82.html
I guess I should post the Engine/Transmission up here for sale as well. I don't have a clue how much shipping would be, obviously I would have to crate it up OR you are welcome to come pick it up. Not sure what to ask for it. I have seen them on Ebay for $12-1500. This one only has 18,080 miles on it so it is barely broke in... lol
If your interested in it please make a reasonable offer. $???
If you can think of any other parts you may need, please ask.
This is the part where you start hollering dibs... lol
Discussion Starter · #4 ·
· Super Moderator
When you say leads are you referring to the spark plug wires or the wiring leading to the coils?
Not sure how much shipping will be, but let me know where you want me to ship them.
Sorry I should have been clearer, spark plug wires. Down under we like to shorten names so we say "plugs and leads" or "coils and leads". LOL
I'll send you a pm with the address.
· Administrator
Good news, Ken is patched up with zombie parts and has the use of his fingers. The rest of the systems should start coming online in time, making the new Ken unit more fully functional. We originally were going to call the new unit KenTronic, but couldn't afford the high-end Japanese parts initially planned for. While the final name is still in discussion we're code-naming him KenTao Stanaslofski.
Discussion Starter · #16 ·
Where in the hell do you find these awful pictures.... never mind, I don't even want to know... lol
OH YEA, Hedgehog, remember what I told you about my Driving Finger. Well here you go. >:) Just about good as new.
sometime you ask the daftest question m8, now he gonna tell us where :wink:
There are some truely sick, demented sexual deviants in this world, but you sir are one cut above. Talk about fugly!:3ek:
1 - 20 of 128 Posts
