Ok, this was started in the thread about who's done the lowering spring & tony's mod, but it's really a separate related issue, so I thought I'd post it here.
Anyway, the question I have is clearance with bars/instrument cluster with aftermarket risers (or without for that matter).
As you can see from the photo, with the cannella risers already canted inward at an angle, the clearance from tank to bottom of instrument cluster is not great. And although I didn't think to turn the handlebars, on sharp left or right turns, the wiring bundles on the handlebars very nearly touch the tank already. What would canting these things a further 8 degree inward do?
Or is the triple tree top kept at the same angle as OEM tree, and the holes into which the fork tops slide cut at 8 degrees? I admit to knowing absolutely nothing about how aftermarket tripletrees would work. [Ignore the fat guy decal on the tank; dunno who snuck in my garage and stuck that on there
