Probably get to mine later this month anything I should know ??
Um, the only tricky part was prying the needle up, I watched the Low and Mean vid on youtube and used their method of prying with a fork but it wouldn't budge. I gently rocked it back and forth and the glue that was holding the needle and round grey plastic cover to the internal "wheel" with the post on it (you'll understand when you remove it) the glue connection broke and the 2 pieces separated. After I got it out though, I used a dab of 2 part epoxy where OEM had put it so it won't come out again.Probably get to mine later this month anything I should know ??
Some do, some don't. Depends on who you get it from and if they went to the extra effort to put those blocking/fading prints on the backside. I know the set I got years ago had an 'approximated' set of these on the backside so my light distribution is not bad, but I'm sure it could be better/closer to factory.I forgot to mention there is one downside of these aftermarket speedo faces. They don't distribute the light like the OEM faceplate. There are things on the back of the OEM one that block/direct where the red light is cast. I didn't try to replicate that on the new one. So the red kinda just bleeds through a bit messy
It's not terrible in the dark, just lights up the whole speedo face in red...but in daylight you can make out the LED's location behind the plate. Not a dealbreakerSome do, some don't. Depends on who you get it from and if they went to the extra effort to put those blocking/fading prints on the backside. I know the set I got years ago had an 'approximated' set of these on the backside so my light distribution is not bad, but I'm sure it could be better/closer to factory.
