Done....PMed and maybe the Mods will move this to the FYI section?
http://www.furyforums.com/forum/fur...-accutronix-3-forward-controls-installed.html
If they are aluminum they are the banjo sealing washers for the brake hose.Well, I put in a call to Captainfester and he walked me through the brake side and I ended up getting it done last night. What a pain in the ass! Wouldn't have been so hard if the instructions had some more detail and was illustrated. Anyway, now I get to take care of the clutch side. Hopefully that goes a little smoother.
Question: I have two thin washers that I can't seem to find where they go..Any ideas?
Yes, that is why there are two of them.Do they go on each side of the banjo fitting leading into the brake resevoir?
Absolutely .. with out them you will spring a leak when you press down hard on the lever!Do they go on each side of the banjo fitting leading into the brake resevoir?
