1 - 3 of 3 Posts
For those of you that have the 3 inch extended forward controls, which way did you attach the banjo fitting at the master cylinder, fitting towards the radiator or outward towards master cylinder? Also which way did you rout the brake line? Thx any info
i have not hooked up the brake light wire yet, but i hope this gives you an idea of what i have going. :D
Snake.Thats how Accutronix said to position the banjo and rout the brake line, it just seems the bend in the the banjo is a little more then it should be.
1 - 3 of 3 Posts
