Thanks for the info.The brake or shift lever can both be adjusted by unscrewing the cap over at the center of the control of the lever. You'll find 4 screwes where you can then unscrew and reset the lever.
I am having difficulty unscrewing the end cap -- any suggestions?The brake or shift lever can both be adjusted by unscrewing the cap over at the center of the control of the lever. You'll find 4 screwes where you can then unscrew and reset the lever.
